맘에 드는 키보드 있으면 한 번 구해보시길 바라며...
by 재아 posted Mar 26, 2018
https://www.youtube.com/channel/UCD0y51PJfvkZNe3y3FR5riw
옆동에 소개 동영상이 있어서 ^^
The Ultimate mechanical Keyboard Video! This is the biggest single collection of mechanical typing sounds ever recorded. Just sit back and drift away on the delicious typing noises 8) . Yes, it contains a bunch of keyboards you haven't seen yet! Many others I have reviewed already; check them out here: https://www.youtube.com/playlist?list... All typing videos were recorded back-to-back, on the same day, with no change in recording setup, and positioned as equally as possible using a directing line made of masking tape, and apart from an equal amount of audio gain applied to all of them to improve audibility, they are unaltered and thus directly comparable. Video clips were recorded in three-hour sessions with 20-minute pauses in between over the period of an entire day. During the pauses I also quickly opened the windows, because it was incredibly hot in the room. All the videos are of ad-libbed random chatter, and don't mean anything. I didn't make an effort to type as well as I could, and I made a lot of mistakes. Yes, this was extremely fatiguing to do, and editing all the scenes took bleeding ages. This typing video represents about two-thirds of the different models in my collection. Much more is yet to come! Visuals: Canon EOS Rebel T3i Audio: sE Electronics Cube4Nano on a Rode PSA-1 boom arm
time - keyboard / switch
0:00 - Chicony KB-5981 / SMK 2nd gen click "Monterey"
0:50 - Zenith Z-150 AT / Alps SKCL Green
1:39 - Chicony KB-5161F / Alps SKCM White
2:29 - Chicony KB-5161C / Omron B3G-S Amber
3:27 - Chicony KB-5191 / Mitsumi miniature yellow, MX
4:26 - Fujitsu FKB4700 / Fujitsu Peerless
5:25 - Tandy 3000 Keyboard / Fujitsu leaf spring 3rd gne
6:18 - Fujitsu MBC-550 Keyboard / Fujitsu leaf spring 3rd gen
7:14 - Fujitsu MBC-885 Keyboard / Fujitsu leaf spring 3rd gen
8:06 - Fujitsu N860-8282-T002 03A / Fujitsu tactile magnetic reed
9:13 - Acer KB-101A / Alps SKCM Blue
10:13 - Acer 6312-KW / Acer switch
11:16 - Acer 6312 / Acer switch (early)
12:00 - Oki HMB-35957-14 / Oki tactile gourd spring
13:03 - Canon AP800 / SMK 2nd gen tactile
14:03 - Cherry G81-8308 LPAGB / Cherry MY
15:01 - Cherry G80-3000 HFMGB / Cherry MX Blue
15:59 - Cherry G80-11906 LPMGB / Cherry MX Black
16:57 - Cherry G80-9009 HAU / Cherry MX Clear
17:59 - Cherry G84-4100 PPAGB / Cherry ML Low-Profile
19:01 - Cherry G81-3000 LPNGB / Cherry MY vintage
20:00 - Cherry G80-3000 LPMGB / Cherry MX Black
21:02 - Cherry G81-8000 LPBGB / Cherry MY
22:06 - Cherry G80-3000 HEMGB / Cherry MX Clear
23:09 - IBM 5251 / IBM Beam spring
24:07 - Chyron 4044 / Key Tronic foam and foil, linear vintage
25:05 - Ace Hall Keyboard / Ace Pad Tech Hall effect
26:03 - Sun Type 5c / Fujitsu dome with slider
27:03 - Coolgreen Fold-2000 / breast implants (LMAO)
28:07 - Syncan TK-105M / Can Tech buckling spring
29:06 - Alcatel MMK / Cherry MX Black
30:10 - IBM Model F XT / Capacitive buckling spring
31:07 - IBM Model M2 / Membrane buckling spring
32:08 - IBM 6112884 "Pingmaster" / Alps SKCC Green
33:16 - IBM P70 keyboard / Alps plate spring
34:21 - IBM Model M (bolt-modded) / Membrane buckling spring
35:27 - IBM Model M 1388032 / Membrane buckling spring
36:31 - IBM Model F AT / Capacitive buckling spring
37:25 - IBM WheelWriter 2 Series 10 / Membrane buckling spring
38:27 - IBM Model M122 1390582 / Membrane buckling spring
39:27 - IBM Model F122 "Battleship" / Capacitive buckling spring
40:29 - IBM Model M122 1394324 / Membrane buckling spring
41:27 - IBM PCjr keyboard / Chiclet keys
42:34 - IBM PCjr revised keybaord / Rubber domes
43:34 - Focus FK-9200 / Focus dome with slider
44:45 - Focus FK-8000 / Hua-Jie Type OA2 Alps clone
45:41 - Focus FK-2002 / Alps SKCM White
46:36 - Focus FK-747 / Omron B3G-S Cyan
47:38 - NMB RT-101+ / NMB Hi-Tek tactile, beige
48:37 - NMB RT-8255C+ / NMB Hi-Tek clicky, black
49:37 - ICL 115807-110 / NMB Hi-Tek tactile, grey
50:40 - Hi-Tek 725 / NMB Hi-Tek linear, white
51:42 - Wang 271-1247 / Honeywell Hall effect
52:40 - Wang 725-3488 / Key Tronic foam and foil, tactile
53:40 - "Project L" / Alps SKCM Neon Green
54:42 - Olivetti ANK-27-102-N / Rubber domes
55:43 - Qtronix Scorpius 104 / Scorpius dome with slider
56:43 - BTC 5130 / BTC dome with slider
57:53 - BTC 5339R-0 / BTC foam and foil, linear
58:57 - Apple A1243 / Chiclet keys
59:59 - Apple M3501 "AEKII" / Alps SKCM Cream Damped
1:01:05 - Apple M0115 "AEK" / Alps SKCM Salmon
1:02:03 - Apple M0116 / Alps SKCM Orange
1:03:10 - Apple llc keyboard / Alps SKCM Amber
1:04:07 - Apple M0110A / Alps SKCC Tall Cream
1:05:07 - Dell AT102 (Alps, old-logo) / Alps SKCM Salmon
1:06:10 - Dell AT102 (Silitek, old-logo) / Alps SKCM Black, pine
1:07:07 - Dell AT102W (Silitek) / Alps SKCM Black, bamboo
1:08:03 - Dell AT102W (Silitek) / Alps SKCM Black, linear-modded
1:09:11 - Dell AT102W (Silitek) / Alps SKCM Black, click-modded
1:10:18 - "Project M" / Matias Quiet Linear & tactile partially undampened
1:11:21 - Dell QuietKey / NMB Dome with slider
1:12:17 - Acorn BBC Master 128 / Futaba ML low-profile linear
1:13:14 - Amstrad PCW 512 keyboard / Amstrad spring over membrane
1:14:13 - Amstrad KB7 / BTC foam and foil, tactile
1:15:13 - Tipro MID DigiPoS / Cherry MX Black
1:16:10 - Northgate OmniKey 102 / Alps SKCM Blue
1:17:08 - Northgate OmniKey ULTRA / Alps SKCM White
1:17:53 - Tai-Hao FAME TH-5539 / Tai-Hao Aruz
1:18:50 - Unikey KB-6551 / Alps SKBM White
1:19:58 - Mitsumi KPQ-E99ZC-18 / Mitsumi hybrid switch, tactile
1:20:57 - Mitsumi KKR-E99AC-9 / Mitsumi hybrid switch, linear
1:22:01 - Datacomp DFK-515AT / Alps SKCM Blue
1:23:09 - Datacomp DFK-700 / Futaba MA clicky switch
1:24:14 - Nixdorf CT06-CT07/M Softkeys / Cherry MX Black ("nixies")
1:25:08 - Alps LCM30 / Alps SKCM White Damped
1:26:12 - Alps SM-101 / Alps buckling spring
1:27:06 - Pioneer AWX-323 / Alps integrated dome
1:28:05 - Texas Instruments TI-99/4A / Stackpole switch grid
1:29:07 - NEC APC-H4122 / NEC oval switch, blue
1:30:14 - Bloomberg FRE-100 Freeboard / Bloomberg miniature domes
1:31:19 - Smith Corona XE1600 / Smith Corona leaf spring over membrane
1:32:21 - BigKeys LX / Alps SKBM White
1:33:25 - KPT KPT-84 / KPT switch, blue
1:34:25 - Siemens k1197 keyboard / Siemens STB 21 A2113-A5
1:35:26 - Tesla 259 "Gerkonic" / Tesla quad-magnet Hall effect
1:36:23 - Zalman ZM-K900M / Kaihua PG1511 Blue
1:37:12 - Corsair K70 / Cherry MX Red
1:38:14 - Matias Tactile Pro / Matias Click
1:39:10 - Topre Realforce 104UW / Topre Switch
1:40:11 - Roccat Suora / TTC Brown
1:41:06 - Bloody B720 Light Strike / Bloody LK1 Optic
1:42:07 - Lingbao Jiguanshi / Gateron KS-8 Blue
1:43:05 - SteelSeries Apex M800 / SteelSeries QS-1
1:44:15 - Cooler Master MasterKeys Pro M / Cherry MX Green
1:45:17 - Logitech G610 Orion Brown / Cherry MX Brown
1:46:17 - Gamdias Hermes / TTC Blue
