SATAN RGB60 FN기능 요약
by 힝힝홍힝 posted Apr 14, 2018
satan rgb60ì ëí ì´ë¯¸ì§ ê²ìê²°ê³¼
SATAN RGB60
별도의 소프트웨어는 없는것 같습니다 ..
키매핑 수정도 안되구요 .. 아래의 기능정도만 사용이 가능한듯 합니다 ㅎㅎ
ps. 제 기판만 그런지 모르겠으나 ..
     평소같은 타건속도에도 키씹힘이 일어나고 백스페이스는 간간히 엉뚱한 문자가 입력이됩니다 ㅠㅠ
FN : 오른쪽 알트 ( 고정 )
RALT : 오른쪽 윈도우키 ( 고정 )
RWIN : 오른쪽 MENU키 (고정 )
FN + "O" Change underglow LED patterns
FN + "\" Change LED patterns
FN + "R ALT" Change direction of LED effects
FN + "R CTRL" Change color of LED patterns
FN + "CAPS" to change color
FN + "R Shift" Increase Brightness
FN + "R Win" Decrease Brightness
FN + "L" Increase speed
FN + "K" Decrease speed
FN + "C" LED Profile 1
FN + "V" LED Profile 2
FN + "B" LED Profile 3
FN + "Z" Per LED Programming - First select the layer you want to edit, then press each key till you see the color you want, then press FN + "Z" again to save. If you want FN to not be lit keep pressing FN till it is white then press FN + "Z" to save. If you want FN to be a specific color, select the color before the one you actually want before pressing FN + "Z" to save. Editing a layer always resets it.
FN + "WIN" WIN lock (multiple presses of "WIN" while holding FN changes color)
FN + "X" Menu
FN + "ESC" ` (FN + Shift ESC for ~)
FN + "1" through "=" F1 through F12
FN + W,A,S,D Arrows
FN + "[" Scroll Lock
FN + "P" Print Screen
FN + "]" Pause
FN + "I" Insert
FN + "BS" Delete
FN + ";" Home
FN + " ' " Page Up
FN + "." End
FN + "/" Page Down
FN + "N" Vol Down
FN + "M" Vol Up
FN + "," Mute
FN + "Y" Calculator
