[MassDrop] VOLTEX RGB KEYCAP
by 힝힝홍힝 posted Aug 27, 2016
[object Object]
Double Tappers
Doubleshot injection molded for maximum longevity, these keycaps are made from PBT plastic, long considered the superior plastic choice in keycaps. The set comes with four CTRL caps (two each of 1.25 U and 1.5 U), four ALT caps (two each of 1.25 U and 1.5 U), three shift caps (one each of 1.75 U, 2.25 U, and 2.75 U), and four card suit caps (1.25 U). As the set is compatible with all Cherry MX switches, it will work with most mechanical keyboard
[object Object]
[object Object]
Specs
  • Vortex
  • PBT construction
  • Double shot legends
  • Cherry MX compatible
  • CTRL caps: 1.25 U, 1.5 U
  • ALT caps: 1.25 U, 1.5 U
  • Shift caps: 1.75 U, 2.25 U, 2.75 U
  • Card symbol caps: 1.25 U
  • Thickness: 1.38 mm
Included
  • Keycap Puller
Shipping
Domestic and international orders will be shipped by Massdrop.
Estimated ship date is Sep 12, 2016.
After the drop ends, payment is collected. To deliver the best value to the group, the request will then be submitted to the vendor up front, making all sales final. Be sure to check the discussion page for updates.
https://www.massdrop.com/buy/rgb-keycap-set
금액 : $10.99 ( 30개 도달시 $8.99)
배송비 : $ 4.5
배송일 : 160912
PBT 재질의 이색사출 제품이며 두께 1.38mm 입니다.
볼텍스제품이라 아마 체리 OEM (마제높이) 인것 같습니다.
TAG •
Who's 힝힝홍힝
힝힝홍힝의 유튜브 채널
https://goo.gl/CfYyGA
많은 시청과 구독 부탁드립니다 ㅎㅎ
