[DESKTHORITY] SKBXX solid bent alu case made in Germany (60%+75%)
by MiND™ posted Dec 02, 2017
독일에서 괜찮은 알루하우징 공제 진행되는 거 같아 아래와 같이 정보 공유해 드립니다.
통알루는 아니지만 각도 조정이 가능하다는 점에서 아이디어가 굉장히 참신한 거 같습니다.
https://deskthority.net/group-buys-f50/skbxx-solid-bent-alu-case-made-in-germany-t17609.html
I'm Plastikschnittstelle. This is an interest check for a keyboard case. It's made of thick aluminium sheets, laser cut, bent and anodized. It's supposed to be a more affordable alternative to all the awesome but also expensive CNC aluminium cases. The design is simple and sturdy, with integrated height adjustability and a low initial row. The plate is edge-mounted. There are different profile versions to decide on - medium, high and high with integrated wrist-rest. This is just the case, no PCB, switches or caps included. We will have to decide which size and layout the case should be adapted to.
01-SKB60H-STNDR-01.jpg02-SKB60H-STNDR-04.jpg04-SKB60H-WKL-05.jpg05-SKB60H-WKL-08.jpg12-SKB60H-angles.jpg13-SKB60H-ex.jpg
