매스드랍) tokyo 60 v3
by 킵너드 posted May 22, 2019
매스드랍에서 tokyo 60 키보드 공제가 시작됐습니다
가격: 230달러
신청기간: 30일
색상: 검, 녹, 파, 은
발송: 11월 20일
SPECS
  • 60 keys
  • CNC chassis with built-in plate
  • Acrylic diffuser (can be positioned on the bottom or between the aluminum pieces)
  • 2-piece aluminum construction (high-profile 6000 series)
  • 5º case angle with chamfered edges
  • HHKB layout
  • Designed in Tokyo
  • Hot-swappable USB-C PCB (solderless kit)
  • Compatible with MX style switches (plate or PCB mount)
  • Cherry profile dye-sublimated keycaps
  • Dimensions, assembled: 11.8 x 4.4 x 1.4 in (30 x 11.2 x 3.6 cm)
  • Weight, assembled: 24.7 oz (700 g)
https://drop.com/buy/massdrop-x-tokyo-keyboard-tokyo60-keyboard-kit?utm_source=linkshare&referer=X5HVJZ
