BOCC 키보드 케이스 공제 (9/7 ~ 9/27 -> 10/3까지 연장)
by 몽쉘 posted Sep 07, 2019
상세: https://geekhack.org/index.php?topic=101417.0
구입처: http://www.thicthock.com/
가격: 300$ + 배송비 35$(서울기준)
Specification of the board:
Aluminium Version
Unlimited
7 Degree
6063 Aluminum
PVD Brass weight
Aluminium plate
Sidebar weight (PVD Brass)
Non-hot swappable Backlit RGB PCB - QMK compatible (ISO supported)
USB-C Port
Double Lock Mechanism
Color options:
- Anodization
Red
Cyan / Tiffany Blue
Pink
Black
- Electrophoresis
White
Yellow
You are able to choose their favourite color combination. You can only match color that is under the same coloring category - eg. Yellow cannot match with Black, Baby Blue cannot match with White.
We will be using the latest electrophoresis technology; the finish will be more durable in terms of scratch resistance and wear resistance.
Polycarbonate Version
Limited quantity of 20
Unlimited
7 Degree
Mitsubishi polycarbonate
Aluminium plate
PVD Brass weight
Non-hot swappable Backlit RGB PCB, QMK compatible (ISO supported)
USB-C Port
